plug wires
  • plug wires
    plug wires 5 & 6 are getting toasted by the headers. what can i do to fix this? my buddy bought plug wires called full metal jackets but a set is $170 i think. little steep for me but they work. does anyone else run stock wires with headers? or did anyone else have this issue and how did they correct it? thanks
    Get a set of wire clips that go over the valve covers and then drop the wires in from the top. That's how we ran them on Mike's (2000Durahoe) 93 Camaro.
      do i have to get special wires? or the stock wires will work? who sell the valve cover clips?
        He bought a kit. Was through SLPonline I think. I don't know if you can reuse stock wires or not. I know he used aftermarket ones that were in the kit.
          thanks tom ill look into it
            It's Thunder Racing, not SLP. Here is the link. http://www.thunderracing.com/catalog...vid=4&pcid=104
            I ran that kit on my car for 2 years with no issues. Sold it and my friend is still using the same wires 4 years after we did the swap.
            2010 Chevrolet Camaro 1SS/RS - My DD
            2001 Chevrolet Tahoe - Duramax/Allison
            2006 Ford F250 - Powerstroke - 6" lift - 37's
            2008 Ducati 1098
            2003 Honda CR250
            2001 Ski-Doo MXZ600
            2011 Ford Explorer - Wife's DD
            2009 Power Wheels Barbie Mustang - Daughter's DD
              looks good i might be ordering this on friday when i get paid
                I seen you got my text and replied to the thread Mike! Thanks.
                  Try using Taylor's fire sleeve boot protectors with the OTVC wire route. Used this method on my car and seems to work great! The boots protect up to 1200 degress and are available through Thunder Racing.
                  Originally Posted by 1BADAIR
                    hmm, i ran my stock wires all last year and so far this year, and no problems.. but i made sure everything was clear of the headers, and zip tied the stuff up if i needed.
                    97 TA AI 355
                    2012 Jeep Patriot
                      Do not use otvc wires - you have been warned
                        Run what ever type of wire that you want.
                        The key is to route them correctly. I have run stock wires in the stock location on my LT1 with headers and have never had a problem with them.
                        97 30th anv Z28 Lt1 Ported Heads and Intake, small Cam, LT's, SLP LM1 w/power flow conversion and cut out, Stalled A4, 3.73, 125 shot or so......... Custom EVI Tune and more to come...... SOLD
                        1971 Suburban work in progress
                        1969 Mach 1 In restoration process
                        Waiting to find the right Fbody
                          they wont help considering its the boot that is getting cooked.
                          its hard to reroute where the boot meets the plug. i wrapped them some new wires in old school high temp tape and put those stock metal 90 degree elbows on the boot to try and deflect as much heat as possible.
                            Could you provide a few more details to your statement rather then "shouting" with huge font? Why not to use them for example.
