the shop here in Grand Rapids is call Performance Engineering... ive used them as well and they do top notch work and would never hesitate to have to work on my stuff again
what optispark?
I used More Power Inc. out in Grand Rapids. Just make sure you double and triple check the block once you get it back from the machine shop, and get a good balance job. It sounds like you have a good idea of what you want for the heads. Just make sure your valvetrain is strong as well (NSA rockers, 7/16" studs, chromoly pushrods, etc.) So by all means go and spend the extra on the bottom end
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Http://www.pereng.com
They even have a PDF price sheet on there site
This is the shop I use as well as my neighbor.
I also used this shop when I did Red's 383 and Josh James (yoeasy69) 383.Last edited by Phantom409; November 30th, 2009, 11:00 AM.
sweet i will check them out.. thanksOriginally posted by kammi10 View Postthe shop here in Grand Rapids is call Performance Engineering... ive used them as well and they do top notch work and would never hesitate to have to work on my stuff again
i think i am going to go with the Harland sharp 1.6 rockers, trickflow chromoly pushrods ect. ill need guide plates also right? a stud girdle isn't necessary right? thanks man ill probably have more questions for yaOriginally posted by ThreeHonks View PostI used More Power Inc. out in Grand Rapids. Just make sure you double and triple check the block once you get it back from the machine shop, and get a good balance job. It sounds like you have a good idea of what you want for the heads. Just make sure your valvetrain is strong as well (NSA rockers, 7/16" studs, chromoly pushrods, etc.) So by all means go and spend the extra on the bottom end
AWESOME.. love the website might just have to take a trip to grand rapidsOriginally posted by Phantom383 View PostHttp://www.pereng.com
thanks alot!
97 TA AI 355
2012 Jeep Patriot
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Not a problem
yes you will need guideplates. i recommend the Isky adjustables (which are a pain in the ass) or the basic trickflows. A stud girdle isn't necessary but 7/16" studs definately are. I also recommend Comp Pro Mags or Ultra-Mags over an aluminum body roller rocker. LS7 lifters are a good choice as are Morels.
EDIT: You are planning on a hydraulic roller application right? or else all of that info is useless lol
alright, i am looking at a summit catalog right now i see the ultra gold comp cams roller rockers is that what you are talking about? i see they have a lifetime warrantyOriginally posted by ThreeHonks View Postyes you will need guideplates. i recommend the Isky adjustables (which are a pain in the ass) or the basic trickflows. A stud girdle isn't necessary but 7/16" studs definately are. I also recommend Comp Pro Mags or Ultra-Mags over an aluminum body roller rocker. LS7 lifters are a good choice as are Morels.
lol and all i see in summits catalog is the comp cams guideplates? and yes i plan on running a hydraulic roller from Lloyd(custom grind)
97 TA AI 355
2012 Jeep Patriot
no im talking about the comp pro mags. look at summit online. if you need any valvetrain parts i have a lot of misc. hydraulic roller stuff. rockers, lifters, chromoly pushrods, etc. pm me if anything is wanted.
Have you gotten your cam specs from LE yet? if you dont mind, post the specs, im interested to see in which direction he is going with his new stuff and what LSA he went with for your build.
these are the rockers he is talking about. its what most people run including myself:
http://www.summitracing.com/parts/CCA-1305-16/-Joel
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Yup, those are top notch rockersOriginally posted by JoeliusZ28 View Postthese are the rockers he is talking about. its what most people run including myself:
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
ac delcos i do believe. no problems after 2 years
I run NGK TR6s. TR55s were too hot for my car.-Joel
too hot? how do you figure? those are nitrous plugs for the most partOriginally posted by JoeliusZ28 View PostI run NGK TR6s. TR55s were too hot for my car.
I run tr-55's but gap them at .035" (found this gives me the best results with my setup.
A lof of people also run autolite 103 or 104s IIRC
