I'd suggest doing that to rule out a fuel issue.
Im stumped!!! Please Help!
aka she-bandit
- July 7th, 2009
- 907
- MiSsY
- 2000 Honda 400EX built *****<3
- at the f**king Catalina Wine Mixer
- bike shop *****
Originally posted by Lucky SOB View PostThe thrown codes should be stored shouldn't they?
yeah,thats what I thought but apparently I was wrong. GM usually stores a code for every little thing!JTS & LTS HAVE MY <3
2008 F150 SUPERCREW XLT 5.4 4X4.....6in lift, 35x12.50s, 5 star tuned
www.facebook.com/youjustgotpassedbyagirl
aka she-bandit
- July 7th, 2009
- 907
- MiSsY
- bike shop *****
LOL maybe so! its that sibling rivalry thing goin on!Originally posted by Old Fart View PostMissy I think our cars might be related.
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
I would check your fuel pressure for 1.
I had a car like your's that I worked on that was acting the same way, run like crap then all the sudden it would run like a champ.
They ended up getting stranded because the opti was going out.
I know it's not what you wanted to hear but it's a strong possibility.
If you still have that test I gave you about a month ago will help you out checking the opti, ICM and coil, all you need is a volt meter.
FWIW - I left the shoutbox after I posted my stuff so I dunno if you saw it or not.
DTC 16 - Low Resolution Pulse will NOT trigger the SES light. According to my OEM Service Manual for '95, Fuel pump and injector operation will be disabled by the PCM if DTC 16 is set. DTC 16 will set when 720 high resolution timing pulses are detected before any low resolution pulses are detected.
DTC 36 on the other hand WILL illuminate the SES light and that's it. The PCM will NOT do anything else when DTC 36 is tripped and according to the OEM Service Manual for '95, it does NOT say that it is stored in the PCM's memory. DTC 36 will set when 40 low resolution pulses occur before any high resolution pulses are detected.
Comparing the two - only takes 40 low pulses to occur to trip DTC 36 which would seem like it'd be more common. If your Check Engine indicator trips because of the optispark, it's going to be DTC 36 and more than likely when someone scans they'll just happen upon DTC 16 at the same time.
I still think it's the optispark.- Brian Meissen
If you want i just bought a data cable and im getting data master we can put that on your car and try a see whats going on
There ya go - that's exactly what Missy needs. I offered to do it at the Spring or Summer Meet & Greet but I realized afterwards that my cable is for a 1995 specifically and wouldn't work on her 1994.- Brian Meissen
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Well Missy, it seems as if your camaro has caught what my camaro has. A very nasty case of the FU's lol. M94 z28 has been laid up since April 30th with relatively the same problems. but mine would die out once it warmed up and would not rev above 3grand. SO i ran all the preliminary tests fuel, spark, did the oil, new thermo, new fuel filter. new plugs, checked my fuses. THen i scanned it-12 codes scanned out. i took it to my mechanic he did a new oil pressure switch a few other things re scanned it got 5 codes. i took it back bc he didnt know where to go. so i took it to a hot rod guy my friend(owns a S/C 91 Z28) recommended. He scaned got a code of no crank signal..replaced the opti ($1300) then it started, but wouldnt accellerate. rand the prelims again fuel pressure tested fine and comp was between 140-150/ cyl. got a low vacumn at idle. so he checked for a clogged cat which came up fine and with straight headed ran 4" vacuum. now he did a timing chain for me...trying to the car is a PITA. Basically what I'm trying to tell you here is don't throw parts at the problem it doesn't help. take your time and run every test twice. keep scanning. I was also told by another mechanic to take the covers off the harness and to run my finger down every wire. if i feel a bump it is probably a corroded wire and that could be the problem since corrosion is a resistor and heat adds resistance. in the end all i have to say is GOOD LUCK
I'm pulling for you
and if you figure it out please tell my what you fixed/replaced. i cant take it anymore
Good Luck
aka she-bandit
- July 7th, 2009
- 907
- MiSsY
- bike shop *****
Well I drove the camaro to work today. Ran perfectly the entire way here. My buddy Brian(one of the techs) and I are going to use a scan tool on it if I can get it to act up today and see what we can come up with....
Im hoping I can atleast find something!JTS & LTS HAVE MY <3
The scan tool should tell you if there's any stored DTCs.- Brian Meissen
aka she-bandit
- July 7th, 2009
- 907
- MiSsY
- bike shop *****
Wellllll........we just hoooked the scanner up to the z....
3 codes came back.
code 42 which was an est code = ?
code 36 which was the pulse code = optispark fail and a big thank you for b, for telling me the codes!
and a code 70 which was the ac clutch relay=why my air doesnt work!
So I will be purchasing an optispark and the Z will be fixed!!!!! YAY!
coil signal wire could be arcing out, swomp rat on here had that. if you where closer to bay city or i was comming that way i could bring over my laptop (i have tuner cats and data master) it could also still be the opti.1997 Camaro SS convertible #594-Gone but never forgotten
