turn signal
  • turn signal
    My left turn signal doesn't blink i just stays on but the four way work fine, all the light blink. Does anyone no why the turn signal doesnt work but the four ways do?
    Front and back just stay on, I thought they did that when one of them where out? Four ways are a different circuit.Rights work fine?
      yeah the right works perfect, and i thought one was burnt out the light just stayed on but both the front and back lights are stuck on and the four way are a different circuit but the same bulb right and they all work perfect.
        Does it have different relays for the left and right? Bad ground somewhere?
          Your bulb is out The bulb that is used for the turn signals has two filaments - one for the flasher and one for running lights. When one of the filaments burn out, the light will stay on solid when you turn the turn signal on. It's either the front or the back, but one of them is going to be burnt out. The 4 way emergency flashers work still because (I believe) it doesn't use the flasher filament, it uses the running light filament.
