My left turn signal doesn't blink i just stays on but the four way work fine, all the light blink. Does anyone no why the turn signal doesnt work but the four ways do?
turn signal
Tags: None
yeah the right works perfect, and i thought one was burnt out the light just stayed on but both the front and back lights are stuck on and the four way are a different circuit but the same bulb right and they all work perfect.
Your bulb is out
The bulb that is used for the turn signals has two filaments - one for the flasher and one for running lights. When one of the filaments burn out, the light will stay on solid when you turn the turn signal on. It's either the front or the back, but one of them is going to be burnt out. The 4 way emergency flashers work still because (I believe) it doesn't use the flasher filament, it uses the running light filament.
