hypertech max
  • hypertech max
    i have a 3:08 rear end 2002 pontiac firebird.
    i recently bought a hypertech max programmer.
    i just need help finding better shift points becuz u can change the rpm the car shifts at.
    they go by 100x rpm for more or less rpm to shift at.
    thanx for ur time.
    Michigan Firebird Club (MIFC) Facebook page
    MIFC forums
    How to join MIFC
    did you program in your gear? you souldnet have to change it much from stock if you have a stock cam. mabey 200rpm
    Sold!
    www.fquick.com/lozanoa11
    94 Grand Cherokee (sold)
    95 Accord(for sale)
    99 Outback (snow destroyer)
      i programmed m gear.
      i have a stock cam.
      and u say about 200 rpm lower or higher.
      becuz im looking 2 improve my acceleration.
      MIFC forums
      How to join MIFC
        The shift points don't really give you a whole lot. I tried to change them and played around while I was at the drag strip with different shift points. It didn't make any difference in my times. I just use the shift firmness at 100% and bumped the rev limiter by 200rpm's. I had reset my computer when I was having problems and never bothered tweaking the shift points again. It's pretty much a hit or miss trial and error deal. If you tweak it too much then you'll hit the rev limiter before it will shift and then you have to lift to get it to shift.
        Wade
          ok thanx for the help.
          MIFC forums
          How to join MIFC
            stock
            '96 Camaro RS - project
            '97 Silverado Z71 - DD
            '89 Suzuki GSXF 750
              yea the reason they give you that is if you have a cam that gives you more upper rpm power you can utilize that but if you have a pretty stock setup then there isnt much you can gain from it.
              Sold!
              95 Accord(for sale)
                i didnt mess with the shift points i only increased my shift firmness 2 100%
                but thanx for all of ur guys help.
                MIFC forums
                How to join MIFC
