Hey All,
So after months of working with a local machine shop on building them a website, I have finally finished my work with them. We have agreed on what my payment shall be, which is basically they will do all machine work, assembly, break in, and dyno my engine for me for free. They can also get me most of the parts at cost (rotating assembly, gaskets, etc)
I would like to get somewhere around the 500hp range with this engine build. and would love to get peoples input and opinions on this build. I was originally going to do an LSx build, but I think a Gen I SBC will work out better since I won't need to worry about as much since it will be pretty much a direct swap.
currently I haven't bought any parts for this project, not even the block. but the plans are so far are something like this..
- 4 bolt main 350 bare block (is this overkill?)
- 383 stroker kit, they said they can get met an eagle rotating assembly (with hyper pistons) for like $500 (should I go forged?)
- Comp cams extreme energy cam? I'm looking for something that will give me some good proven power, I hear a lot of good things about these
- Heads? not sure what to do for these yet.. because if I buy new.. then I waste any benefit from them being able to do all the work for free, was considering vortec, but not sure how if they would be good for the HP I would like to get
- What kind of valves / springs should I do?
- rocker arms (ratio, type, etc?)
- flat tappet or retrofit roller?
- where should my compression ratio be at? what cc heads/pistons should I be considering
There are a lot of things that can play out here obviously.. I would just really like some solid input on what direction I should go..
Things to consider
- Car is currently an auto (700r4) but will be converted to a t-56 at some point
- Car will probably very rarely see the drag strip, but it will go occasionally.
- Car will be carb'd at first, but will probably swap out for a fiTech efi setup eventually
- Car will not ever use nitrous, and I don't at this time have any plans to do a forced induction setup on this engine, if I want to go that route, I would probably sell this engine and buy an junkyard LSx and turbo that.
Things to consider
Definitely this.
