So you're saying you don't wet sand the base coat? Isn't that why factory cars like the fbodies are know for orange peel? Or is that the clear coat?
Removing Paint and Rust
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
- Greenville, MI
- Die Maker
Base doesn't get sanded unless it sits for a while. Never sand metallic or pearl.Originally posted by 1BADAIR View Postbase usually never gets sanded. I dont beleive metalic can be sanded
Media blasting is a *****. I don't think I'll ever do any type of abrasive blasting again unless it's crushed dry ice. For now I'll stick with chemical dip of any removable panels
My understanding (someone correct me if I'm wrong) is that it's the clear coat. Joel and others have wet sanded their factory clearcoat to reduce orange peel.Originally posted by Fox Slaughter View PostSo you're saying you don't wet sand the base coat? Isn't that why factory cars like the fbodies are know for orange peel? Or is that the clear coat?- Brian Meissen
Correct. The orange peal is in the clear not the base.Originally posted by meissen View PostMy understanding (someone correct me if I'm wrong) is that it's the clear coat. Joel and others have wet sanded their factory clearcoat to reduce orange peel.2002 Z28 Camaro A4
^ditto these two.
And TJ i say that because of the amount of equipment i had invested in the finishing process alone. You gotta really love body work to do it and do it well. Its hard on your body.-Joel
