MIFbody Loan A Tool
    i have a 3/4 drive set it might have a 60mm or something close
    00 Tahoe Z71........Stock
      I have 1" torque wrench and 3/4 adapters so..
      the stamp steel axle sockets won't work. Has to be torqued to ~350ft lbs
      mine is stamped, sounds like you impact quality, sorry bud I don't have those that size
      Originally posted by birdie2000 View Post
      Jesus, what are you working on, a locomotive?
      Ever did a lift kit on a 2003 f350 super duty ? big truck...gotta have big sockets
        dont those have solid front axles? just longer radius arms, steering components and that sorta thing?
          yup solid front axle, that and beefier
            i dont remember using a 60mm socket on any of the lifts ive done, hmmmmmm
              ok ok. i changing a turn signal switch
                Gotta make sure that stalk doesnt come loose. Bad day when it comes off in your hand, kinda like when the Cruze first came out the steering wheel problem.
                Originally posted by Yoshi94
                  i didnt say i used a 60mm socket on the lift kit, but I had to buy a monster truck socket set, size starting at 24mm on up and my envoy takes a 36mm for half shaft retainer nuts
                    36? Or 35. Usually nobody has a 35
                      I need more sockets.
                      definitely not enough wrench's either
