Thought dexcool was formulated for alum. block,radiators and heads. However I could not find this stated anywhere
Coolant question
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
dex cool will be fine its basically a weak acid based coolant from all ive learned and thats why some cars have gasket issues. Its suppose to be better for water pumps , as the green stuff doesnt offer as good of protection, if i remember correctly its been quite awhile since ive read about coolant.sigpic
The LS1 or Go Home Crew
ASE master certified
A easy comparison for example a 2000 Camaro with a 3.8 V6(cast iron block/ heads aluminum intake/radiator) had dexcool and the same car with a 5.7 (all aluminum) had dex cool as wellOriginally posted by Plum Nuts View PostThought dexcool was formulated for alum. block,radiators and heads. However I could not find this stated anywhere
All I know is when I see these 100K+ mile cars come into the shop and NEVER had any cooling system work done to them ..... it's a mess. The radiator caps are completely plugged, the radiators are plugged, the hoses are destroyed, the overflow bottles are fogged up. Green stuff usually doesn't make such a mess from what I've seen.
They're basically equals in my mind. Because as long as you change your fluid once in a while you'll be fine. Personally, I run green stuff in my '91 bird with a cast iron boat anchor in it.
It ain't too bad...I've done it twice in the past 30k miles.Originally posted by bri2203 View PostThe radiator shop I deal with says it is more of a 4 year 80,000 mile coolant, which reminds me I need to flush the coolant in the tuner.
The original DexCool had an over-aggressive additive package in it that ate through many seals in certain engines (mainly the 3X00 series V6s). They revised the coolant additive package, and have put it in every GM vehicle since then. I rarely, if ever, hear of a coolant problem caused by the newer DexCool.
I have it in my Cobalt, and I've put it back in (as I said above) twice, as well as in the heat-exchanger loop.
Megan's Cavalier will get fresh DexCool as soon as I drain the old shit out...I'm pretty sure it's never been changed.
Last edited by MP81; September 24th, 2012, 12:35 PM.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
I've got Be Cool's biodegradable coolant in my car if I do remember correctly.- Brian Meissen
Oooh, fancy.Originally posted by meissen View PostI've got Be Cool's biodegradable coolant in my car if I do remember correctly.
I prefer the coolant that specifically states it is terrible for the environment and living things.
They donated it to me at the Meet & Greet a few years ago.
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
If you'd like to join the hundreds of Class action lawsuits for people with destroyed motors due to DexCool, use it.
If you want to save your engine, new or old - drain that garbage out the day you get it home, and refill with Prestone All Make All Model.
Not only do you save your motor, you'll drop it 5 degrees.
Never Mix Green glycol with Dexcool. It can form a Gel inside the radiator and plug the cooling system.
I've done many intake jobs for co-workers and friends. I have had 1 engine destroyed, and 1 damaged due to Dexcool in my personal fleet.
Further, in any vehicle with dexcool I can pretty much put down a $100 bet that the gaskets are malformed and require replacement - leaking or not.
My 3800 Intake repair guide on my forum had over 1200 hits in a few weeks before I locked it down. The 3.1L and 3.4L guides were quickly trailing in hits.
FLUSH IT OUT!Last edited by TrickyTransAm; October 21st, 2012, 06:58 AM.
