Ok two questions here. My father has a gen 1 350 we rebuilt the motor, (long story shorter) we made a huge mistake and accidentally swapped 2 pistons and installed them in the wrong cylinders. These are high compression pistons and we had a high lift cam so we had to make sure the valve reliefs were in the right location(which they were not). We trashed lifters, cam completely toast, one intake valve completely sheared, and one piston unsalvageable along with cylinder wall gauge, one cylinder head is all beat up(pic).
So first question can this head be saved? ( hoping welded and then re-machine the combustion chamber and valve seat)
second if it can does anybody know who could do it?
these are dart heads we bought would like to salvage but were expecting there not worth doing.
WHAT A EXPENSIVE MISTAKE!!!!!!!
luckily the lifter broke off the other cylinder and only put a little gouge in the piston( valve seems to look ok)
