Just like the title states...anyone deleted their ABS? Which kit do you have?
ABS Delete Kits, who runs one?
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Mine is just a T-fitting for the front and a female/female union connector for the rears. No proportioner. Previous owner did it, claimed everything works well. I have experienced no problems with it, seems to stop just fine to me although I'm no expert on braking bias and what improper bias would feel like. Then again, I do have C5 Z06 brakes up front so that could affect the bias since the fronts now have more stopping power.
Did my own. Used tees to connect and an adjustable proportioning valve.
Works great. Cleans up the engine bay, less weight97 30th anv Z28 Lt1 Ported Heads and Intake, small Cam, LT's, SLP LM1 w/power flow conversion and cut out, Stalled A4, 3.73, 125 shot or so
......... Custom EVI Tune and more to come...... SOLD
1971 Suburban work in progress
1969 Mach 1 In restoration process
Waiting to find the right Fbody
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Don't feel bad about it. That's pretty much why my cars take forever to get done.Originally posted by erk2581 View PostEverytime I've said "oh they make a kit for that, but I can do it myself for cheaper, it won't be too bad" I end up hating myself over it lol. I'm having the same debate with a ram air setup right now...
Because racecar?
2001 Bright Rally Red Camaro SS - M6, Livernois Stage 3 ported 243 heads, Livernois 230/236 114 LSA cam, FRPP 36# injectors, Ported TB, SLP MAF, Volant CAI, Kooks 1 3/4 headers & ORY, GMMG Cat-back. Koni SA 4/3's, BMR springs, Founders Performance, STB, LCA's and Panhard bar.
I deleted all that shit, Made new lines strait from the master. looped around through the inner fender and they disappear from there. for pass front, I ran the line under the core support in the little channel. it's nice to pull the motor out the top, or drop it strait out the bottom and not have to disconnect a line at all. also, my line lock is mounted on the frame rail on the drivers side front.... I also have the 4 piston Aerospace drag brakes at all 4 corners.... they work better than the stock units by a long shot1998 Camaro SS Bullseye Turbo
