alright so i have had this problem since last fall and am just getting around to fixing it since summer is just around the corner. the rear brakes just barely seem to engage at all.
brake system consists of stock master, ssbc adjustable prop valve, aero space street brakes up front with wilwood drag rear discs. has 3/16's lines to both fronts with 1/4 inch out back and split into two 3/16ths to each side.
i have pumped and bled both sides and am not getting any major pressure like it should. you can feel the rear calipers clamp down a little but not enough that you can not still move the rotor by hand.
fronts clamp down great but the rears do not.
any idea's?
any idea's?
