new 98 roller.jpgbought a 98 z28 today. deep blue, 1 owner car. t top, leather interior. it was an a4. the owner took the motor/ trans out of it to install in a 90's rx7. i'll keep this thread updated! and post some pics as soon as i get it home.
Gaspo's 98 z28 build thread
Last edited by Gaspo; March 8th, 2012, 09:41 PM.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater -
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
pics or ban?- 2012 Mustang GT 5.0 - M6 / Brembo Package / 3.73 / Bama Tune / Catless X / Corsa Xtreme /
what i'm thinking is pulling my motor out of my car, rebuilding it and putting my stock heads back on. buying an intake, fuel rails, injectors, wire harness, computer and transmission and putting it in. probly with some long tubes, but stock motor. or a friend of mine has a complete pull out from a 2000 trans am. might buy that and throw it in.Originally posted by mcalus View PostWhat's your plans for it? Pics or gtfo
does anyone know this? the car is a 98, but if i have a 99 and up complete setup, computer, harness, engine and trans, will it work? i know the 98 is different with a few things.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Tits or GTFO i mean pics.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
i'll get pictures up asap. its the deep blue color. has stock exhaust. stock z28 rims with really good tires. tan leather interior, but the seats are all cracked to hell.. that might be going black leather from my silver car, and then some different racing type seats in the silver car.Originally posted by Fox Slaughter View PostTits or GTFO i mean pics.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
I think everything from a 99 should work. The main issue with the 98's were the ECU pins are different from the 99-02. As long as the PCM is from the 99 you're good unless you want to do some repinning.-08 G8 GT DD: Rotofab CAI, HID's, Breyton Race GTS'
its a complete pull out, the body was scrapped i guess so thats good news. thanks!Originally posted by shawnc16 View PostI think everything from a 99 should work. The main issue with the 98's were the ECU pins are different from the 99-02. As long as the PCM is from the 99 you're good unless you want to do some repinning.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
so the car has been sitting in the unit, havent had time to touch it. out on vacation. have a motor/trans combo coming from new jersey, should be here friday. when i get back from florida on saturday hoping to get to work on it! everything is stock on the car. think i should go with solid motor mounts or stock replacement motor mounts? the car needs new seats, the leather is torn on these ones. is it worth re doing the seats or buying complete replaacements?98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
