Gaspo's 98 z28 build thread
    Poly just think about it a motor rocks due to torque and if you have solid mounts it will torque into the chassis. Unless its a drag car only go for it.
    Originally posted by Yoshi94
      Looks like it could use a turbo kit!
        i think i'll go with the stock one.. the car is going to be completely stock anyway. Jonny, this car isnt going to be turbo'd but one will be soon. i'm looking at a fully built 6.0 camaro that could use some boost...
          if you get rid of the tan seats lemme know, might be interested
          00 Tahoe Z71........Stock
            will do. they are not in good shape tho.
