Wondering ware you all are getting your 12 bolts and 60s from or maybe a recamendation on a place with quality peices and prices . I'm lookin at strange and moser but I'm wondering witch one is better and or if there's any other places around .
i need a rearend .
Obsessed
- April 23rd, 2011
- 561
- David.
- 1997 formula firehawk and 69 chevelle.
- jackson Mi
- auto body painter well i recenly have been forced to retired due to health problems.
Obsessed
- April 23rd, 2011
- 561
- David.
- jackson Mi
I'm not really wanting a 9 inch thanks tho if idid I think I'd use a m9 . Ile check tech and see what there is I want a 4.30 gear and id like a complete assembly ready to go.sigpic1997 firehawk # 115 6 speed. Its just a little ole LT1
Obsessed
- April 23rd, 2011
- 561
- David.
- jackson Mi
It's just a preference on not running the 9 inch I'm actually leaning towards the 60 id like to find a place local thats good if not I'm just guna order onesigpic1997 firehawk # 115 6 speed. Its just a little ole LT1
DTS can get you an S60 locally. not running a 9" is fine but remember they are so popular for a reason.Doing less with more
exactly.. parts are typically cheaper and they are much easier to work on.. and yes 12 bolts and 6 speed cars dont mix.. ask larry (1badair)Originally posted by DETROITMUSCLE View PostDTS can get you an S60 locally. not running a 9" is fine but remember they are so popular for a reason.
Obsessed
- April 23rd, 2011
- 561
- David.
- jackson Mi
Yeah I here ya on the 9 inch and thanks I forgot about them ile give them a call.Originally posted by DETROITMUSCLE View PostDTS can get you an S60 locally. not running a 9" is fine but remember they are so popular for a reason.sigpic1997 firehawk # 115 6 speed. Its just a little ole LT1
Obsessed
- April 23rd, 2011
- 561
- David.
- jackson Mi
The S60 is a good rear axle, much better than a 12 bolt, but the 9 is better. There really is no excuse not to buy a 9" axle if you are going through the pain and suffering of buying a new axle assembly.Originally posted by DETROITMUSCLE View PostI'm not an S60 hater by any means I think its a great rear end and would own one myself, but I don't see any reason to not have a 9"sigpicTurbo Charged LS1/T56
We should break it all down in a thread but I think I can see the S60 being cheaper. A base S60 is $2350 if you reuse your backing plates and its a bolt in piece, still needs a new DS but so does a 9". The base S60 will handle much more power though and it doesn't require a high dollar center section like a 9" and comes with 35 spline axles out the box. The weakest link is the tru-trac and if they can be optioned with a spool that would mean its even cheaper and will handle whatever you can throw at it for much less than a 9". I would say an S60 with a wave-trac or spool should handle just as much power as a 9" with a better center section.Originally posted by WMCCjames View PostThe S60 is a good rear axle, much better than a 12 bolt, but the 9 is better. There really is no excuse not to buy a 9" axle if you are going through the pain and suffering of buying a new axle assembly.Doing less with more
Obsessed
- April 23rd, 2011
- 561
- David.
- jackson Mi
I've heard people talk about the 9inch raising up the car in the rear I really don't want that I'm sure the 60 will be fine for this car I really can't go to the track much right now maybe will more time my lungs are pretty jacked up so if they ever heal up I'm sure to be there as much as I can I'm just sick of putting money into my ten bolt .sigpic1997 firehawk # 115 6 speed. Its just a little ole LT1
