Replace pilot bearing????
    Originally posted by Nocooler View Post
    Levi, go to Autozone and rent a pilot bearing puller - should only take a few wacks to get it out. Tap the new one in. Did it come with a bearing or bushing?
    Do this^ The tool is made for it and works like a charm. I re-used my flywheel and pressure plate bolts and haven't had any issues.
    What brand clutch did you get? I recommend measuring the thickness before re-installing. I had a RAM clutch and I pulled my trans 3 times before figuring out that the clutch was the reason it wouldn't disengage (too thick!). Better to take a few minutes and check than go through the headache I did!
    1996 Trans Am, Red M6: HotCam Kit, LS1 Brake Upgrade, MGW Shifter, MadZ28 Tune, Meziere E-WP, Morosso CAI, Pacesetter LTs, Hooker catback, UMI SFCs, Lakewood LCAs w. relocation brackets, front lowered 1.25", BBK underdrive pulley, 160* thermostat, detailed engine, customized interior, custom Firebird sub box.
    349 RWHP / 344 RWTQ
      Yup i plan on grabbing that tool tomorrow. I went with Competition Clutch, Stage 2. I have some ARP Flywheel bolts, but I plan on re-using the pressure plate bolts since those only torque to like 22ftlbs.
        Ok everyone, thanks for all of the replies!! The swap went pretty smooth untill we had to put the trans back in, lost about 3 qts of fluid and then it down poured and water came into the garage and made a nice mess but in the end everything worked and clutch feels great, just gotta start breaking it in before woodward.
