Replace pilot bearing????
  • Replace pilot bearing????
    ok so i have my trans and clutch out of the car for a clutch swap. My rear main is clean and looks fairly new, no leaks so i am gonna just leave it since its not leaking. My question is should i replace the pilot bearing? how hard is it to replace? I have one that came with my clutch kit from Competition Clutch. Car has 93k. Thanks
    Levi, go to Autozone and rent a pilot bearing puller - should only take a few wacks to get it out. Tap the new one in. Did it come with a bearing or bushing?
    2000 Formula
    fixed slow junk
      Absolutely replace since you are there already.
        its actually a bushing. Also my next question is, does someone have part numbers for the flywheel and flexplate bolts? if you do can you PM them to me please. Thanks guys.
          Nevermind i bought these. can i re-use the pressure plate bolts?
          http://www.summitracing.com/search/?...200-2807&dds=1
            ARP makes pressure plate bolts too - call up summit and have them add them to your order.
            2000 Formula
            fixed slow junk
              Use an air drill with a small bit and drill a few holes around the old bearing to relieve some pressure. Then you're going to have to grind out part of the center to get the puller to fit.
              Used to own a Firebird.
                when i did the clutch on my v6 i just packed the back of the crank with grease and it pushed the pilot bearing out...
                1995 Firebird Formula (Sold but not forgotten)
                1998 Camaro Z28 LS1
                2003 Silverado 2500HD CCSB 4x4 6.6 Duramax (DD with minor mods for better "MPG's")
                2004 Trailblazer LT3 i6 4x4 (wifes ride)
                  did i see you on M46 at the intersection by the ford dealership on thursday evening????
                  sounds like a pain in the ass. thanks tho!!
                    I might have been there - my car wasn't though, still waiting on the trans....
                    2000 Formula
                    fixed slow junk
                      i seen a forumla same color as yours at the light, thought it might have been you.
                        This can also push your water plug in. Not a good idea.
                        -Homer Simpson
                          I have another question also, i bought brand new GM master and slave hydraulics but the ones on the car look almost new and work perfect so i dont really wanna replace them if they are fine. I also need some extra cash right now.
                            The LT hydraulics aren't as fickle as the LS stuff. Try it if it works - return the new stuff, if not replace it.
                            2000 Formula
                            fixed slow junk
                              yeah thats what i was thinking also. I'll probably sell it for a little bit cheaper than i bought them since i bought it over the winter.
