NHRA Legal killswitch/battery relocation??????s
  • NHRA Legal killswitch/battery relocation??????s
    Decided I am going to make my Battery relocation NHRA legal.. Going to build a box similar to this(I will attach this to my BMR mount I already have), needs to be a hair smaller to fit in the spare tire area though.. Anyone have links to Kill switch installation/install pics? I am going with a switch, not the push/pull.... any suggestions on where the easiest place to install the switch on the TA?
    http://cgi.ebay.com/ebaymotors/Batte...item4aa72567de
    this doesnt exactly help you but here is when i mounted mine
      lol, you are correct....
        Only place I can think of would be the center panel between the tail lights... maybe even the lock cylinder hole?
          Not a bad idea... Will have to look into it
            also seen done thru license plate so new plate would cover hole if ever decide to change.also seen push/pull done this way
              So you pull the plate at the track and mount switch. When done racing pull switch, put plate back..
                You could do something where the switch is in the trunk with a rod and handle coming out a small hole. When you're not racing, just remove the rod and handle and all you have left is a small hole that is easy to hide.
                When in doubt, Whip it out !
                  license plate area sounds like a great idea.
                    I agree! Good thinking Rick!
                      Ive got mine w a push pull i mounted the switch to the Antenna bracket and the rods coming out the rear bumper
                      Edit: kinda similar to this
                      http://i226.photobucket.com/albums/d...risAvery28.jpg
                      http://i226.photobucket.com/albums/d...risAvery26.jpg
                      Edit:: Also my battery box is mounted on the passenger rear frame rail. As my fuel pumps are mounted in my trunk. but as Kammi Says "RACE CAR"
                      04 dodge ram HemiGtx 001/433
                      08 yamaha R6 (fuel saver)
                        racecarssssssssssssss
                          No race cars here...
                            kinda like this but maybe just enlarge plate bolt hole? have seen push/pull done this way to. Might have to move when you get your parachute tho.lol good luck!!
                              [ATTACH=CONFIG]32947[/ATTACH]
