Decided I am going to make my Battery relocation NHRA legal.. Going to build a box similar to this(I will attach this to my BMR mount I already have), needs to be a hair smaller to fit in the spare tire area though.. Anyone have links to Kill switch installation/install pics? I am going with a switch, not the push/pull.... any suggestions on where the easiest place to install the switch on the TA?
You could do something where the switch is in the trunk with a rod and handle coming out a small hole. When you're not racing, just remove the rod and handle and all you have left is a small hole that is easy to hide.
kinda like this but maybe just enlarge plate bolt hole? have seen push/pull done this way to. Might have to move when you get your parachute tho.lol good luck!! shut off resize.jpg
