Thoughts on this car please
  • Thoughts on this car please
    I'm definitely interested in buying it, but I don't know enough about LT1 cars to tell if it's been done right or not.
    http://www.ls1lt1.com/forum/showthread.php?t=39352
    The car is ridiculously clean and it gets comments wherever it goes.
    motor is a fresh less 3000 miles forged 355
    mahle raceweight forged aluminum pistons
    polished crank
    pink rods
    ARP bolts throughout
    comp xfi 292 cam
    comp hardened pushrods
    PBM 1.6 ratio aluminum roller rockers
    heads are fully ported with 2.02 1.60 ferrea race stainless valves
    intake is ported
    pacesetters long tube ceramic coated headers
    loudmouth exhaust with a moroso spiral flow muffler
    twin 58mm bbk throttle body
    canton valve covers
    msd 6al box, 95+ msd opti-spark, msd coil, & msd wires
    K&n setup from Ls1
    Glasstek Hood
    zex wet shot
    GM ss spoiler
    air/fuel ratio gauges on pillar
    255 walbro in tank fuel pump
    new starter
    160 thermostat
    Mezeire electric water pump
    pro fab k-member
    eibach pro kit springs
    UMI rear suspension with 3 way adjustable drag shocks
    Spec 3 clutch
    Billet Flywheel
    solid motor mounts
    Car will hold a 150-200 shot. It makes 436hp at the REAR WHEELS on motor only. If someone wants a sweet lt1 ride this is it. AC/ABS removed. Trans was just freshened up when motor was done so it has only 3000 miles on it new hurts shifter and short stick
    comes with the weld pro stars
    car has the rare red insert seats in it i have a pic of that
    car runs awesome. front bumper cover has 2 tiny bubbles right at the turn signal. i have a new front bumper. it definitely does NOT need a new bumper. im sure im forgetting alot of stuff. the car has over $12,000 invested
    I WILL ONLY ACCEPT TRADES OF DIESEL 4X4 TRUCKS OR LIFTED JEEPS. IF ITS NOT WORTH $10K, I DON'T WANT IT! NO IMPORT JUNK!!!
    $8,200 obo
    Andrew
    Kouts, IN
    219-476-6919 (call/text)
    That's a pretty serious build, and it's a sharp looking car. He also used quality parts, mahle, arp, comp, pacesetter, etc. Looks to be "legit" as they say.
      mmmm nice color. Wont know unless you went and took a look at it really. It could look really good on paper untill you see it in person and do an inspection. But from looks of it looks pretty damn clean exterior wise. Known parts also no weird brands.
        Definitely worth a road trip for a "look-n-see".
        Clamaped up tighter than a 15 year old on her first prom date...
          Wasn't there a car just like that on here at one time?
          Looks really nice from that picture.
            do it do it do it.. Great looking car.. a lot of quality parts on there also...
              car sounds pretty nasty vid in his sig btw
                x2
                yeah it definitely looks like a great deal, worth taking a look at it for sure
                  Looks like a killer deal on a killer car...I say do it! Def worth a closer look if you're serious, should sell quick.
                  1999 Trans Am NBM M6 || Stock short block || Livernois stage 2 LS6 heads || Speed Inc. SI5 cam 231/237 .589/.595 112 lsa || LS6 intake || P&P throttle body || F.A.S.T. 36 lb.injectors || Ls6 oil pump || New timing chain, gears and cam bearings || GM performance lifters || Comp pushrods || Comp 918 valvesprings || SLP lid || SLP underdrive pulley || Jethot long tube headers || ORY || Borla exhaust || Hurst short throw shifter || LS7 clutch || BMR lowering springs || Tubular control arms || BMR panhard bar || BMR torque arm || 4.10 gear || 10 bolt rear with welded axle tubes and a TA Performance girdle || Drilled and slotted rotors || SLP subframe connectors || BMR driveshaft loop || SLP Firehawk hood || SLP Firehawk Wheels || Nitto Drags || EVI Dyno Tune 436RWHP/ 413RWTQ
                    pink rods...
                    Used to own a Firebird.
                      Looks like a sick car!
                        He has a lot of cash into that car. If it is as he states I would say thats a very good price. Beautiful Camaro!
                          All that time an effort put into the engine, yet nothing is said about the transmission or the rear end. I'd definitely test drive it to make sure both are intact.
                          Also, if you want to take the matter into your own hands, invest in a cheap ProVision scope and probe that engine every which way you can to confirm the parts that are what the seller claims. It's also good for checking the overall physical condition of the internal engine. If the seller refuses your request to probe the engine, walk away.
                            has a nitrous kit on it, thought you didnt want a car with the dreaded std
                              this.
                              Also, that engine is still running an opti. If this is a build that wants to be revved to 7k all the time, thats gonna give you problems. The good thing is that you can convert to a complete LS1 ignition now. The bad thing is it costs an arm and a leg.
                              Other than that i dont see any problems with it. The front bumper near the driver said turn signal looks effed up in a couple of the pics.
