I'm definitely interested in buying it, but I don't know enough about LT1 cars to tell if it's been done right or not.
http://www.ls1lt1.com/forum/showthread.php?t=39352
The car is ridiculously clean and it gets comments wherever it goes.
motor is a fresh less 3000 miles forged 355
mahle raceweight forged aluminum pistons
polished crank
pink rods
ARP bolts throughout
comp xfi 292 cam
comp hardened pushrods
PBM 1.6 ratio aluminum roller rockers
heads are fully ported with 2.02 1.60 ferrea race stainless valves
intake is ported
pacesetters long tube ceramic coated headers
loudmouth exhaust with a moroso spiral flow muffler
twin 58mm bbk throttle body
canton valve covers
msd 6al box, 95+ msd opti-spark, msd coil, & msd wires
K&n setup from Ls1
Glasstek Hood
zex wet shot
GM ss spoiler
air/fuel ratio gauges on pillar
255 walbro in tank fuel pump
new starter
160 thermostat
Mezeire electric water pump
pro fab k-member
eibach pro kit springs
UMI rear suspension with 3 way adjustable drag shocks
Spec 3 clutch
Billet Flywheel
solid motor mounts
Car will hold a 150-200 shot. It makes 436hp at the REAR WHEELS on motor only. If someone wants a sweet lt1 ride this is it. AC/ABS removed. Trans was just freshened up when motor was done so it has only 3000 miles on it new hurts shifter and short stick
comes with the weld pro stars
car has the rare red insert seats in it i have a pic of that
car runs awesome. front bumper cover has 2 tiny bubbles right at the turn signal. i have a new front bumper. it definitely does NOT need a new bumper. im sure im forgetting alot of stuff. the car has over $12,000 invested
I WILL ONLY ACCEPT TRADES OF DIESEL 4X4 TRUCKS OR LIFTED JEEPS. IF ITS NOT WORTH $10K, I DON'T WANT IT! NO IMPORT JUNK!!!
$8,200 obo
Andrew
Kouts, IN
219-476-6919 (call/text)
polished crank
pink rods
comp xfi 292 cam
intake is ported
canton valve covers
K&n setup from Ls1
Glasstek Hood
zex wet shot
GM ss spoiler
new starter
160 thermostat
pro fab k-member
Spec 3 clutch
Billet Flywheel
solid motor mounts
$8,200 obo
Andrew
Kouts, IN
