stock fuel pressure regulator for 98 tank
  • stock fuel pressure regulator for 98 tank
    i was wondering from this picture which is considered the stock fuel pressure regulator... i was thinking maybe it has the tube connected to it going to in between my twin pumps?
    in the pic i took out the spherical plastic yellowish thing mounted on the cap of the assembly idk what it is exactly... thought it was the FPR
    i have a external FPR mounted on the rails... i just needed to know so i dont have to fight for the fuel pressure that is needed.
    Thanks
    98 NBM Z28 A4 Cam ONLY 11.94 at 113 1.7 60'
    233/239 .598/.603 113 LSA tuned by me, 3500 TCI SSF
    turbo build in progress... Build Thread
    Body repair build thread
    TEAM LSWON
    round black thing with the clip. remove clip, separate , remove diaphram then put back together
    Atleast thats how the older ones work
      Thanks larry... i knew you would know.
      i made a mistake and took out the check valve i think, now i need to open er back up and actually remove the FPR
      TEAM LSWON
        that one may not be able to remove the inards. may have to remove the whole thing. the clip by your thumb
          Thanks i'll figure it out now since i got the right component lol
          and i'll have to put back in the check valve
          TEAM LSWON
