Something wrong?
  • Something wrong?
    When I let off the gas pedal while moving I hear a clunk from the rear and my car juts, I have no idea what it is. maybe the rear end going out? Any ideas
    Could be a u-joint, the slip yoke, loose u-bolts on the axle. Bad tranny mount, loose lugs on the wheels. usually the tans mount would clunk if you peg the gas... good way to check it maybe lol..
    ASE Certified Automatic Transmission Mechanic
    I would rather push a Chevy than drive a Ford
    Remember folks stop lights timed for 35mph are also timed for 70mph.
    94 Camaro Z28 LT1 396 sigpic
      It sounded fine when I would lay on it, only when it would take my foot off. It also wasnt very consistent it would go away for short periods of time. Its not the lugs.
        is it just one clunk or a continuous clunking noise
          Just one
            yeah my bet is on the u-joints, i would go under and check for play in the driveshaft,, maybe even binding of the slip yolk. shouldnt be a real big hassle to fix
              k ill check it out thanx
                bump. for any more ideas
                  did you check u joints? that would have been my first guess. Sounds like something to do with the driveshaft (which could be u joints)
                  -Derek-
                    Im gna check em first thing when I wake up
                      The camaro does something similar. You don't notice it at light throttle to about 1/2 throttle. Only 1/2 and up under hard acceleration and you have to let off completely. Its the trans mount on the Camaro. I never remember to get one when I drive up to autozone though.
