What kind of cam is it? Solid, hydraulic? I like to do them while the car is running (hydraulic) i loosen the rocker arm nut and then tighten it finger tight. then i take the nut on the inside and tighten that. then take a wrench and tighten the rocker arm nut.
2015 Silverado
If you have a Haynes or Chilton manual it's laid out well in there.
I don't have mine handy or I would run it down here for ya.
When you are adjusting them I can tell you that once you fell pressure on the push rod give it a 1/2 -3/4 turn and go from there.
Best way to start is to spin the push rod in your fingers till you feel it contact the rocker and the do the 1/2-3/4 turn.
Hope this helps?
Bring the cylinder to the Compression stroke, wiggle the rocker til it just touches the pushrod then tighten another half turn. I think.. off the top of my head
