yes you are a yooper
LS1 swap into the IROC underway
I would Have to agree with this statement. Its got to be 50 degrees in my garage before I will stay out there for any length of time.Originally posted by WMCCjames...... You see, I ENJOY working on my car.....working in 35 degrees is just not enjoyment in my book.
You say that like your proud of it or something.Originally posted by MattODoomHell... I am a yooper afterall.
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"2017 Silverado Double Cab Z71 Pepperdust Metallic, 5.3, A6, 3:42, "SASYZ71"WMCC Website www.wmcamaro.org
are willing to work and give to those who would not." — Thomas Jefferson
It's been awhile....haven't been able to work on the car much because of how cold it's been. I did FINALLY finish up my cold air intake. This was a bigger task that I thought. I knew I wanted 4 inch tubing and I wanted it mandrel bent and polished. After looking a bunch of places, I found this UJ mandrel bent stainless steel pipe from a place in Canada. I also ordered up all the t-bolt band clamps and silicone connectors I needed.
The stock MAF on these motors is 3.5 inch OD and the throttle body is a 4 inch OD...so I used two silicone reducers to make the transition to and from the MAF. I was able to find a HUGE 4 inch K&N filter at the local speed shop.
Anyways, this turned out to be a bit hard to fit into the space I had....it took many attempts and LOTS of trimming and fussing. I'm pretty happy with the way it turned out....I like how I was able to run the pipe under the upper radiator hose outlet...also kinda hides the MAF under the hose. I got lucky with the rad hose....fits around the tube awesome without touching it.
sigpicTurbo Charged LS1/T56
James, I have been following your project with much interest. I am very impressed with your attention to detail, and your ability to not let any problem go unsolved. I belive your swap is first class, all the way. I'm very excited to see the old '85 back on the road. It's gonna be awesome!
My hat's off to you! (If I wore a hat, that is ...
RIP Doug,You will always be remembered
3/3/53 ~ 12/22/10
1985 Camaro IROC-Z
1974 Camaro Type LT / Z28
2002 Trail Blazer LTZ
1996 Camaro SS (Sold
www.wmcamaro.org
Thanks guys!
Matt.....um, keep expecting
Sean....sure, how much money you got?
Wade....the stock TPI dual snorkle is a very restrictive piece....ever look inside one? Dyno tests have proven it is restrictive on a low speed high torque motor such as the TPI, high speed motor....forget about it.
Doug......thanks buddy, hope we can cruise our 85's together sometime this summer....hint hint
I am the same way...I've wanted to put an LS1 into a 3rd gen for a long time but you level of detail is very impressive.Originally posted by WMCC DougJames, I have been following your project with much interest. I am very impressed with your attention to detail, and your ability to not let any problem go unsolved. I belive your swap is first class, all the way. I'm very excited to see the old '85 back on the road. It's gonna be awesome!
You should sell your tips to one of the 3rd gen websites!
AWESOME JOB JAMES!!!!!!!!
It won't be long now before the old
is
Yeah, what he said!!!!!!Originally posted by WMCC Dino
'73 Z28 388 Stroker, M22 Rockcrusher 4 speed
WMCC Photographer and owner of Redline Photography
You are only young once but you can be immature your whole life!!!
InActive Member
- March 8th, 2006
- 1269
- Dennis
- 1985 Black Camaro IROC-Z, 1970 El Camino
- Spring Lake, Mi
- MARINA OWNER / RETIRED
Ol' Rock N'roller
Count me in on crusin with the third gens, if you don't mind havin a "black" third gen hangin around...Gotta break up all that white.
James,"OL Time Rock n' Roller on Board "
