my buddy is buying a 1990 camaro rs and it had a tbi 305 in it.... and he wants to put a carbed 350 in it and he wants to know what he needs and what needs to be done....
carbed 350 swap
InActive Member
- April 8th, 2006
- 154
- Jason
- 94 Pontiac Firebird
- Essexville, Michigan
- Grocery Store
Pretty simple actaully..head on over to thirdgen.org and look through there...all the info you need will be there...it's alot more of a tech site than this one. Basically though, you will have to regulate the fuel pressure down to 6-7psi. Get a carb and manifold and a non-comp controlled dist. Unhook and remove all of the EFI harness and ECM. You will have to use one of several methods to control lock-up on the torque converter and also your electric fan. You will also have to bypass the VATS system too.sigpicTurbo Charged LS1/T56
