carbed 350 swap
  • carbed 350 swap
    my buddy is buying a 1990 camaro rs and it had a tbi 305 in it.... and he wants to put a carbed 350 in it and he wants to know what he needs and what needs to be done....
    94 Pontiac Firebird...Stock with flowmaster american thunder dual cat back system
    Pretty simple actaully..head on over to thirdgen.org and look through there...all the info you need will be there...it's alot more of a tech site than this one. Basically though, you will have to regulate the fuel pressure down to 6-7psi. Get a carb and manifold and a non-comp controlled dist. Unhook and remove all of the EFI harness and ECM. You will have to use one of several methods to control lock-up on the torque converter and also your electric fan. You will also have to bypass the VATS system too.
