i need help removing lifter on my trucks 350. they are hydraulic flat tappet lifters and they are literally stuck in the block, i can pull them up with a screwdriver byt the retainers till they are flush with the bore but after that i can only pull them halfway up with a pair of vicegrips. ive tried oiling them, tried to pull them out stuff it back in and so on so forth but to no avail. ive only gotten one out sucessfully and ive never had this much trouble with them. usually they just fall out, these no so much. if anyone has any ideas i should try, or is in my general area and wants to come take a wack at it then id appreciate any help given.
lifter removal
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
lifter removal
00 Tahoe Z71........Stock
97 K1500 lt4 cam, 1.6s, MPFI, Solid axled, IROKs,------winter beater -
Post Whore
- 3000
- Tyler Porter
- student
Originally posted by 1BADAIR View Posthttp://www.summitracing.com/parts/wm...FY9DMgod9wQAww
slide hammer for pilot bearings will usually work91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
i personally never seen a lift the wouldnt slide out...what would be the cause of something like this to happen ?'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
If you need one. I have a complete blind hole puller.
Ranging in sizes.
Put them into the pushrod cup.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thoseOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Post Whore
- 3000
- Tyler Porter
- student
Originally posted by Fox Slaughter View PostIf you need one. I have a complete blind hole puller.
Ranging in sizes.
Put them into the pushrod cup.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Lurker
- March 13th, 2010
- 3476
- TJ
15 mile and Groesbeck/Gratiot.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thoseOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Post Whore
- 3000
- Tyler Porter
- student
oh im right behind the police station north of 16 on groesbeck, your not far at all.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Lurker
- March 13th, 2010
- 3476
- TJ
I've never used it to pull lifters but thats all I can assume is to put it in the lifter cup and pull them.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thoseOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Post Whore
- 3000
- Tyler Porter
- student
what time do you get off work? if i can borrow it i can probably stop by once my mom gets home since ill have to use her car, unless your up to dropping it off if im not too out of the way.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Lurker
- March 13th, 2010
- 3476
- TJ
I am home around 4:30.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thoseOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
