I've been toying with the idea of an engine swap, im not lookin for a crazy drag car but would like somethin along the lines of 350-400 RWHP, i have an lt1 but i feel like it'd take quite a bit of work, so if anyone has an insight itd be appreciated, ive thought about finding an ls1 to build while still driving the car, a 5.3 swap, or next winter pullin the lt1 and rebuilding it. As far as which would b the cheaper and easier route to go please let me know! Id like to keep it N/A and without a bottle too. I'd like to keep my stock trans (t-56) and rear end also, rear end was just rebuilt with 3.73 gear. Would an ls/5.3 bolt to the lt1 t-56?
So ive been thinking about an engine swap?
InActive Member
- May 22nd, 2011
- 406
- Josh McCabe
- 1998 Camaro Z28 LS1
- Troy, MI
- I'm a Technician at Hamilton Chevrolet
1995 Firebird Formula (Sold but not forgotten)
1998 Camaro Z28 LS1
2004 Trailblazer LT3 i6 4x4 (wifes ride) -
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Um a AI valvetrain will put you over 350whp in a M6 and with their heads you would be looking over 430whp. You can have a valvetrain, heads intake manifold ported by them for under 4000.
No the LS1 uses a different bell housing also has push (if I recall) and the LT1 has a pull style clutch or its the other way around.
Budget 350/355 (350 bored .030 over)
http://www.rpmmachine.com/eagle-stre...mance350.shtmlLast edited by Fox Slaughter; March 20th, 2012, 09:41 PM.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
No such thing as budget engine swaps. If you're only looking for 350-400rwhp, I'd just do a heads and cam kit.- Brian Meissen
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Agreed.Originally posted by meissen View PostNo such thing as budget engine swaps. If you're only looking for 350-400rwhp, I'd just do a heads and cam kit.
I was looking into doing this exact swap with almost the same power goals (mine were ~390-400rwhp with a tame idle and RV-like torque) and while you might be able to build a decent budget engine, all the other parts and such will nickle and dime you to death. In the end, as much as I hate to keep dumping money into an LT1, it still makes sense at this point for my goals and budget.
Hell, you can get 350rwhp in an M6 LT1 car pretty easily with just a cam swap, and even then the cam wouldn't be all that big.
InActive Member
- May 22nd, 2011
- 406
- Josh McCabe
- Troy, MI
Alright thanks guys. I drove it all last summer n now this summer it just doesnt seem as fast/fun haha. Any suggestions on cam/heads? Should i just port stock heads or upgrade them? its got 99k on the clock, would it b worth a full teardown n rebuild or just do top end for now n wait til the bottom end goes? Id like a lopey cam too, its not a daily driver other than nice days so it wouldnt bother me much. But would still like to have the reliabilty factor1995 Firebird Formula (Sold but not forgotten)
1998 Camaro Z28 LS1
Lurker
- March 13th, 2010
- 3476
- TJ
Www.advancedinduction.comOriginally posted by blacklt1firebird View PostAlright thanks guys. I drove it all last summer n now this summer it just doesnt seem as fast/fun haha. Any suggestions on cam/heads? Should i just port stock heads or upgrade them? its got 99k on the clock, would it b worth a full teardown n rebuild or just do top end for now n wait til the bottom end goes? Id like a lopey cam too, its not a daily driver other than nice days so it wouldnt bother me much. But would still like to have the reliabilty factorOriginally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
What I would do - if you're willing to spend the money for a swap - I'd get a heads and cam package from advancedinductions and then also pick up the LS1 pcm conversion kit so you can get rid of the optispark. Then you'd have reliability and power.- Brian Meissen
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
Why not do the LT4 conversion kit from Summit. Manifold, heads, cam all in a package directly from GM ready to go. 425hp factory designed.
The only way that kit will get you 425hp is if you add 100 hp NOS shot with it.Originally posted by TrickyTransAm View PostWhy not do the LT4 conversion kit from Summit. Manifold, heads, cam all in a package directly from GM ready to go. 425hp factory designed.sigpic
Obsessed
- 593
- C
- MI
- Engineer
425hp isn't that difficult when you think about it. Good flowing heads, high compression, and a cam can get you there without nitrous. 425 at the wheels is a different story.Originally posted by ryanwarby01 View PostThe only way that kit will get you 425hp is if you add 100 hp NOS shot with it.
Has someone on here or yourself purchased that kit to debunk it?Last edited by TrickyTransAm; March 27th, 2012, 06:29 PM.
You can definitley get a h/c/i kit good for 425+ hp, it's just not the LT4 kit. I had that kit on my lt1 for a long time and never dynoed anywhere near 425 crank hp. A stock LT4 was good for 330hp and that kit isn't good for another 100hp on top of that.Originally posted by TrickyTransAm View Post425hp isn't that difficult when you think about it. Good flowing heads, high compression, and a cam can get you there without nitrous. 425 at the wheels is a different story.
Has someone on here or yourself purchased that kit to debunk it?sigpic
