I'll take it
v6 to v8 swap 2002 camaro.
The 6 speed wont be a problem, Just need some pedals. and a hole in the floor.
As far as the fuel pump. Id say just leave the stock one. My 1995 has a ls1 (headers/3500 stall) in it and I have a stock 3.4 v6 fuel pump in it, It works great. If you look at the flow ratings the v6 pumps are only 5 psi lower. It may lean out alittle, Im not sure. But it works.
When I looked up the specs on the 1996 3.8l pump and the one for my 1995 LT1 it looked like the V6 pump capable of more pressure.Originally posted by Curt_irocz View PostThe 6 speed wont be a problem, Just need some pedals. and a hole in the floor.
As far as the fuel pump. Id say just leave the stock one. My 1995 has a ls1 (headers/3500 stall) in it and I have a stock 3.4 v6 fuel pump in it, It works great. If you look at the flow ratings the v6 pumps are only 5 psi lower. It may lean out alittle, Im not sure. But it works.sigpic
1996 Base Model
+2 cylinder mod
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
The problem with the v6 pump is if you mod the engine ie: cam, larger injectors, the v6 will lean out the tune at higher RPM. Not good, best to change it up front or plan to do soon after swap.sigpic
And soo would the stock v8 one. Either way if your going to do cam/heads/injectors etc. You going to at least need a walbro 255.Originally posted by Plum Nuts View PostThe problem with the v6 pump is if you mod the engine ie: cam, larger injectors, the v6 will lean out the tune at higher RPM. Not good, best to change it up front or plan to do soon after swap.
i think u should turbo that v6 and call it a day cheaper and can be just as fast or faster =DOriginally posted by Outlaw-53 View PostWell guys thanks for all ya help now its the waiting time and see if I can get this donor car. I'll keep you all updated once the time get closer.2000 WS.6 Build <--- click to see
1994 cummins turbo diesel 1million+ miles!! (rip dad)*my fathers old truck hell of a mechanic!
The 98+ v6 pumps are the same as the ls1 pumps. It's the buckets and stuff that are different, I as well as many other have used all of v6 stuff and I'm now even running the cammed 6.0 with it. You just have to redo some of the fuel feed lines and use the Corvette fuel filter/prssure regulator.1999 Camaro - 6 liters of fury.....
I'm not familiar enough with the pumps to know if they have to be changed or not. I thought LS1 cars run at a higher PSI, but I'm not sure how that works with the LT1's fuel pressure regulator on the fuel rail...- Brian Meissen
My only why not will be the wiring disaster. 99+ uses the data bus for the cluster. No idea how your ever going to make that work.
Plus your 93 is OBDI vs the 02's OBDII. I think you will really end up hacking the car apart to make it work. But thats up to you.
Just my $.021999 Camaro - 6 liters of fury.....
It would be cheaper to buy a 5.3 and put it in then to ever get a free lt1 in it. Plus nothing is ever free with a lt1.sigpic
