The 6 speed wont be a problem, Just need some pedals. and a hole in the floor.
As far as the fuel pump. Id say just leave the stock one. My 1995 has a ls1 (headers/3500 stall) in it and I have a stock 3.4 v6 fuel pump in it, It works great. If you look at the flow ratings the v6 pumps are only 5 psi lower. It may lean out alittle, Im not sure. But it works.
When I looked up the specs on the 1996 3.8l pump and the one for my 1995 LT1 it looked like the V6 pump capable of more pressure.
The problem with the v6 pump is if you mod the engine ie: cam, larger injectors, the v6 will lean out the tune at higher RPM. Not good, best to change it up front or plan to do soon after swap.
And soo would the stock v8 one. Either way if your going to do cam/heads/injectors etc. You going to at least need a walbro 255.
The 98+ v6 pumps are the same as the ls1 pumps. It's the buckets and stuff that are different, I as well as many other have used all of v6 stuff and I'm now even running the cammed 6.0 with it. You just have to redo some of the fuel feed lines and use the Corvette fuel filter/prssure regulator.
I'm not familiar enough with the pumps to know if they have to be changed or not. I thought LS1 cars run at a higher PSI, but I'm not sure how that works with the LT1's fuel pressure regulator on the fuel rail...
I already had the LT1 sitting around from my 93Z found a really really cheap 2002rs so why not havn't bout a new part yet, all from fbody owners local and all over only thing I'm buyng new is my 24x because I have not seen a used one for sale yet.
