Hey guys, how hard is it to swap the motor in the camaro because Ive never changed a motor in a camaro? Would it just be easier to tear some stuff off the motor and go out the top?
3.8 motor swap help
swapping in a new 3.8 or going to a different type of engine?
Out the bottom is the easiest, drop the kmember, engine and trans all as one. No need to take the engine apart then.------------------------------------------
5th gen Camaro V6 Forums
http://www.bowtiev6.com
putting in a 3800 from a 97 camaro. I know i need to change the intake because they are different. But idk if i feel comfortable lifting the car up to change the motor. Im gonna do it myself with a buddy, and ive never taking a motor out of a camaro before.. Plus i dont have the money to go pay for it to get done
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Dropping the motor out the bottom is by far the easiest way. Put rear tires on tires and rims from front this gives good ground clearance in back. Drain fluids, pull radiator and hoses, disconnect brake lines at anti lock unit. disconnect battry harness, and PCm harness and fuel lines. Disconnect drive shaft at rearend, and trans shift cable. Then take cherry picker and lower front on to a 4 wheel dolly. Disconnect the top shock bolts and then the 3 kframe bolts on each side. then lift body slowly and make sure everything disconnected. Lift body high enough and roll engine and trans out from under car.
I have done this 4 times and most of what I detailed above you have to do to pull out the top. There is a thread on here that gives list of steps and pictures. Includes build in licoln log stack to rest car on while engine out.
Edit:
I forgot to tell you to disconnect the exhaust. The engine harness also has 3 wire that are plugged in under dash on passenger side. Rest of harness can come out with engine.Last edited by 98blackbeauty; May 16th, 2011, 09:05 AM.sigpic
InActive Member
- April 11th, 2009
- 274
- Christopher
- 1998 Trans Am
- Battle Creek, MI.
- Managed Services System Engineer at NuWave Technology Partners
Ditto to what Plum Nuts said ive done 2 this year and its real easy to pull it out the bottom, here is a good write up with some pix http://www.michiganspeed.com/enginepull/index.html1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
Pioneer D3 HU, Infinity Reference 6.5 componets. Kenwood KAC-9104 1800w AMP, Kenwood KAC-8404 600w AMP, Subthump Stealth enclosure, PPI PRO104 2000 watt DVC Sub
