<Project> 2000 Trans Am
  • Thanks guys - having trouble uploading the start-up video to YouTube. Apparently I can't just log into my old account, it wants me to use my gmail email account.
    Anyways back to the project.
    After I had everything hooked back up, I went to fill the clutch reservoir with fluid so I could bleed the clutch. When doing so, I noticed there was fluid dripping out of the bell housing. So I bought a trans jack and pulled the trans. It was leaking clutch fluid out of the new slave cylinder that I had installed the Tick remote speed bleeder to. Apparently you are supposed to disassemble the fittings that come assembled and apply sealant to the threads. Once I did that, it held fluid and I was able to bleed the clutch. After bleeding it with the speed bleeder, bleeding the old fashioned way, etc I still could not get a firm clutch pedal. I ended up buying a vacuum bleeder and pulled vacuum from the reservoir and got all the air out. GREAT - FINALLY! So now time to start it up...
    I get it started, but cannot get it into any gear in the front of the pattern (3,4,5,R). This problem ended up being that I had the reverse lock-out connector plugged into the skip-shift solenoid and vise versa. I still can't believe they made those with the same pigtail connector...
    So I finally am able to drive it down the street, but it is almost impossible to get it into the reverse and the gear lever jumps forward about 1/2" when you let the clutch out in 2nd gear only. So I pulled the trans out AGAIN and took it back to the guy that rebuilt the trans. We think we found the problem with reverse (Probably something with the lock-out solenoid. I may have had the skip-shift eliminator plugged into the reverse lock-out accidently), but the trans guy is working on the second gear issue still.
    I'm hoping to have it back this week, but I'm at the mercy of the trans guy getting the rebuild manual to check all the shims.
    The good news is while I had the car together with the trans marginally functioning, I was able to get an alignment put on it and the AC charged. It will be ready for the tune once the trans is back in!
      Fun project, this was good practice for when I do my overhaul .
      Even after being heavily involved in Kolin's LS1 and LS7 projects, I still made mistakes and learned a lot on my own car.
      • Man, why do t56 rebuilds never seem to turn out well? That sucks!
          It's always a learning experience, even on the same basic engine.
            Ive noticed this too. The few the proud, the T56 rebuilders. lol
            Good look Fred, my trans is mint 1-6 but has the common Reverse pop out. Cant bring my self to fix it right now.
            • Congrats Fred can't wait to see it in person!
                They're expensive to do anything on. I thought when I took it to this guy to have the 3-4 shift fork replaced I'd be looking at a few hundred bucks. Well after being talked into doing a rebuild while he was in there I was into it for $1k. From what he's told me, it's a total PITA to work on.
                • Good news is I can have the car in complete running form to transmission-less in less than an hour! The hydraulic trans jack for the lift was one of my best investments
                    *cough* hiretherightpersonthefirsttimehelps *cough*
                    (lol, sorry Fred.....had to )
                    • Start Up Video!
                      • sorry to hear about the trans issues fred!
                        hope its fixed soon so we can do some side by side comparisons with my stock T/A
                        Pewter '02 WS6 Trans Am, M6 LS1
                        2000 Crown Victoria LX (DD)
                        Red '
                        95 Z28 Camaro, M6 LT1 (SOLD)
                        Pewter '99 Firebird. A4 3800 (SOLD)
                        • Originally posted by OVRKILL View Post
                          I fully agree with you. Seems like liberty gears and detroit gearbox are the only shops that have a consistent track record with these things.
                          I hear all the time that "T56s are such a complex transmission to work on" and yet a friend of mine rebuilt his own in his basement with zero transmission experience whatsoever. 5 years later its still surviving behind a stroked Ls2 with an abusive driver. Go figure.
                          • reverse popout is very easy to fix and takes like 15 minutes
                            • Update: The transmission is ready to be picked up. He said he changed a shim, so 2nd shouldn't move around anymore.
                              • Congrats, looks like the first start went smoothly from the engine side of things!
                                Which jack did you get and where did you get it from? Been casually browsing for one as well. Thinking I might be doing a clutch in the near future and that would help tremendously.
