POR-15 is a great paint for a used diff. We painted the 10-bolt in Sam's Monte, and man does it look sharp!
LS1 Swap
what kinda jack is that, looks like it would be awesome for a transmission99 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
Originally posted by ThreeHonksI like having a loud car, every time the neighbors dog barks, I just go let my car sit and idle in the driveway
Update!!!!! It's in!!!!
I only had a 2 hour window this morning between 8am and 10am to do the work. Not bad if I do say so myself.
Later tonight, I managed to get the torque arm relocation mount / tranny mount in place along with the torque arm:
[img]http://emulsified.smugmug.com/photos/963239446_ybZ3Q-L.jpg
I also goofed off and loosely bolted up the front lower control arms to see how awesome they look:
If I bust ass for the next nine days, there's a good chance I'll have it finished up for Dream Cruise. We shall see...
will be checking one of these out, need it, done too many trannys on my back..Originally posted by Emulsifide View PostAs you said, it's a transmission jack and it works AWESOME. I got it from Harbor Freight.99 Buick Regal GS- New DD
No pictures tonight. It appears there's definitely going to be some clearance issues with the driver's side portion of the exhaust. I'll get that figured out.
I managed to assemble the majority of the front suspension tonight. I need some new ~1" 3/8 grade 8 bolts and nuts to hold the bottom of the struts to the lower a-arms since they were not included. That's definitely holding me up at this point. I also had a hell of a time tonight with the steering rack. I managed to unscrew one of the old tie rod ends without loosening the jam nut...which appears to be frozen. Go figure. I did this with the rack on the car. Tomorrow, I'll yank the rack out again and throw the damn rod in my vice and get that nut to come off.
Other plans for tomorrow include the following:
1. Piece together the rest of the front suspension and tighten everything down.
2. Assemble the drive shaft safety loop and install.
3. Install the drive shaft.
4. Install the fenders and some plastic pieces.
5. Potentially begin the rest of the work in the engine bay (radiator, wiring, brake lines, etc).
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Your making good progress, can't wait to see it done at the dream cruise.sigpic
Thanks for the comments guys. I didn't get nearly as far as I wanted tonight, but that's ok. I managed to get off the jam nut from the steering rack rod by locking the rod in my big ass vice with a 3 foot breaker bar and then spinning it off with 600ft/lbs of impact wrench torque. What a pain in the ass. The other side came off much easier.
The passenger side suspension is finished aside from the sway bar. Here's a teaser pic:
The caliper is on for mock up. All Zerk fittings are greased and all bolts are torqued to spec. Now it's just a matter of getting a brake line to it and cleaning/installing the fender well plastic and the fender. It's starting to look like a car again!!!
Take it back Jess!
