jc's LT1 rebuild thread!
    Originally posted by Plum Nuts View Post
    When do you plan on doing this? maybe Brian and I could swing by and lend some help.
    ill take down brians number and give you guys a call and let you know when were doing what!
    its at my grandparents house right around crooks & long lake, by the giant cemetary
    1996 Trans Am. 355 LT4 + some go fast mods.
    www.360icons.com
    _ Do you have what it takes to become an icon?
    _
    <Atmosphere> Call of duty mw2 summer 10' Ladder
    Gamebattles.com
    Perlsh
      Originally posted by Z28_84 View Post
      that would be awesome! make sure you keep me updated on that
      We've been looking for weeks now, I know its in the basement somewhere. ill look some more tonight.
        the lt4 hotcam right?
          yes
            Yup, know exactly where that is. My mom and I worked at the building that's right along I-75 across from the cemetary on the north side of Long Lake Rd. DeLorean is buried at that cemetary.
              ok!
              so i just got the rest of my money for this rebuild, i have $1300 for this rebuild all to be spent in the motor, i know its not much but it will get it back on the road. plus i already have a lot of things, 1.6 roller rockers, valve springs, valves, retainers, etc. and the top end is pretty much all new & rebuilt. im going to buy the speed pro LT1 rebuild kit out of summit for $600 and that includes: 10.4:1 forged pistons w/ rings all my clevite bearings every seal / gasket for the motor, and a new oil pump + freeze plugs. i also get my machining done for VERY cheap because i used to work there..
              so with the $700 left over .. what should i buy? most importantly? i just want to make sure im getting the most bang for my buck with this project
              www.360icons.com
              _
              Gamebattles.com
              Perlsh
                Well, first off, I would pm creight/cs3 automotive on here about all parts that you are buying. He can get A LOT of stuff, and usually cheaper than anywhere else. With that extra 700 if I were you I would look at suspension.
                  ill have more money for suspension parts come around time to paint my car.
                  i need to get headers/y pipe and a tune though so i think ive drained the rest of my $$ with that..
                  www.360icons.com
                  _
                  Gamebattles.com
                  Perlsh
                    Pace Setter LT's & Y-pipe with ceramic coating is 600 by it's self so ya you have used your 700.
                    If you are going pull the trany & motor out the bottom is best.
                    Other wise I like to go through the top when I do it.
                    Good luck with your build
                      i've never pulled a motor from the bottom but i want to just try it, and everywhere i look says its much easier.
                      the pacesetter lt's im getting are $285 ( non-coated ) that im wrapping & the y-pipe is like.. $115? im pretty sure, and i have the rest of the exhaust taken care of.
                      www.360icons.com
                      _
                      Gamebattles.com
                      Perlsh
                        I would look around for used parts, i got my Hooker coated longtubes and a jet hot y pipe for $300 barely used. that gives you $400 to put into other stuff.
                          suspension wise you can get umi tubular LCAs and a panhard bar for under $200, sub frame connectors are another good idea
                            on the SFCs.
                              i may have missed it but did you talk about a cam? what about a lt4 intake or something of that nature? just suggesting
                                He said he doesn't want to do a cam anymore.
