Now that you've done that, squirt about 2-3 tablespoons of oil into the cylinder and do it again.
Does it slow down the leakdown?
If so, it's your rings.
If not, it may be in the head.
If it is in the ring area, I would check the cylinders to make sure they aren't egg shaped. You may have a trashed block if water was creeping in.
I call it the 3800 disease.
