i need help identifying my engine
  • i need help identifying my engine
    i am having problems buying part for my engine because i dont know what it was from and the year so can you guys help. i have the number off the block that is on the passenger side right in front of the head the # 15B607905 ku. can anyone help because i cant find it anywhere on the net. my engine is a small block chevy 305.
    thank you in advance
    I can't find those numbers either, you sure they're right?
      I think that number is the partial vin that is stamped on the block.
      There should be another number, possibly above and to the right of that one, that will start with a letter and end with either 2 or 3 letters (likely 3 letters) with numerals in between.
      This number should be a larger font and maybe not stamped as deep.
      From the partial vin, I'm guessing that the 15B indicates it's a 1985 vehicle built in the Baltimore plant, which means it's likely a pickup/van or El Camino block, which means it's likely a 150 hp 2-barrel 305 motor.
      But the other code will confirm for sure.
        the other number is K07 08 CMJ
          i think i figured it out can someome tell me if i am right the # is K07 08 CMJ so is the engine made in canada on july 8th 1980 305 fullsize/camaro. is that what you get.
          thank you
            That would appear to be right...
              IF it's a 305...the partial vin doesn't make sense.
              If it's a 305, the engine was born at the St. Catherine, Ontario plant on July 8th, 1980 and was intended for a full size Chevy or Camaro with an automatic transmission.
              Are you sure it's a 305?
              I'd double check...might be a 350...there's also another usage for CMJ, but that's from the mid-70s...and that would make the partial vin make sense...
                what should i double check on to see if it is 305 or 350
                  See if there is a number cast into the side of the block...don't remember what side...
                  Or if that isn't there, measure the bore and maybe we can get it that way...
                    ok i tried to find numbers on the side of the block but i cant see the side of the block because it is in the car and all ready to go other than a gasket for the carb and a starter. i can get numbers off the back of the block if that helps the numbers on top of the bolt place for the bell housing.
                      this number on my engine is 3970010
                        according to this number it's a 350 from the year 69-80
                          That makes sense...that would make it a 1975 350 "Police" block with a 4 barrel carb for a Chevy full size car.
                          If you can, I'd measure the bores anyway...just to make sure.
                          If that's what it is, it's a solid block, and a nice find.
                            ok i have to go get a starter is there a auto parts store that could tell me what it is without taking the whole top end of the engine off since i dont have a torque wrench.
                              no.
