4th Gen Carbureted Motors & Legality?
  • 4th Gen Carbureted Motors & Legality?
    First of all i would like to know if we have any 4th Gen guys here that have a Carbureted Motor.
    Is there any legal repercussions from doing this? Emissions challenges?
    I will probably have more questions to add to this.
    Why put a antique on a newer car?
      Just weighting options.
      It would be a lot easier to do a V8 swap if did not have to mess with all the computer & wiring involved with an LS1 swap.
        I think I've seen 1 somewhere on the internet. Just have to look around.
          Its the only way to do it right.
          Carb on a 4th gen ranks right up there with hacking a hole in your floor to change the fuel pump.
            I talked to the parts guy Don at Berger for a while about the Carb LS2 crate engine. He said he has a few friends who have got them and they absolutely love them since they'll pull higher than the F.I. LS1s/LS2s. I was thinking about that Carb LS2 motor for the next project since it really is a very easy install and comes with 440hp out of the box with no worries and a warranty! That'd be the easiest V8/M6 swap ever.
            88' Trans Am 350 TPI
              Now that sounds like it would be a nice motor.
                YOU CAN DO THAT? SWEET!
                  Ive been thinking bout this also, carbed motor with a M6 swap, i dont think putting a carbed motor in a newer car is bad just says you like the style of new but the power of old.
                  Mods:
                  Ram Air Intake (CAI)
                  K&N Filter
                  Polished Throttle Body and MAF Sensor
                  De-screened MAF Sensor
                  Tightened Throttle Body Cable
                  Performance Button Setting Changed for Torque
                  160* HypterTech Thermo
                  Water Wetter
                  New Distributor, Plugs, Wires
                  New Water Pump
                  LT4 Knock Sensor
                  Flowmaster 40 Series Muffler
                  TB AirFoil
                    technically it's illegal in all 50 states, but who is going to check it?
                      you can buy a wiring kit that has everthing labled and is easy as pie.. just a couple hundred bucks.. sure beats running a carbed car
                      if your going to do a swap.. why mess with a carb!!
                        where would you get a wiring kit like that? I may kick that idea around too.
                          Just buy a complete motor/trans/harness to begin with. My bosses father in law bought an LS6/M6 with a harness out of his buddies 'vette for $1500. The damn thing only has like 23k miles on it!!!! It's sitting on a pallet in the barn at my work as we speak. I thought about getting a clean as hell 98+ V6
                          and offering him 2k for the motor/trans
                            Is this what you are taking about Dan?
                            http://www.painlessperformance.com/w...rchField=65106
                            If so that may be the best solution.
                            Correct me if i am wrong, but from what it looks like all i would need is this Painless kit, an LS1 motor, a M6 transmission, electronic Gas pedal, and various mounts.
                              I used a Speatech harness when I did my LS1 swap..literally it was hooking up 5 wires, easy as pie. Why lose half the benifit of of swapping in an LS1 by throwing a carb on it??
