Height of ls1
  • Height of ls1
    I am working on possibly doing an ls1 swap into my bravada, and need an overall height from bottom of oil pan to top of intake. I have to have it sit a bit higher due to the front diff in the way(just about 1/2 inch or so I think or is that hope?)
    check ls1tech.com
    this swap has been done
      i have no data for you but like larry said its been done before
        65 lbs. lighter than LT1(that weights 525lbs)
        26" Bellhousing flange to crank pulley
        28" Bellhousing flange to front of water pump
        25" Bottom oil pan to top of manifold
        12.5" Bellhousing flange to center of motor mount
        15" Bottom of oil pan to bottom of exhaust ports
        26" Wide to outside of exhaust manifolds
          damn james do a little measuring in your car
            Thanks, all the info I can find on ls1tech shows 2wd models, mines awd
