sum*****, wrong forum lol, someone move this to the appropriate forum, well, now that i think about it, its ALMOST a kill.....my own car getting killed by bad coolant lol
In Loving Memory of Eric James Binney
10/9/1987-6/30/2007
Rest In Peace my friend.
Bad Company Racing-Founder and President
Kills for 2008 with the 1994 Firebird Formula
None
coolant flush ftw. Wow thats bad. Get it done cause if u over heat those aluminum heads will warp and then u have to get them milled. Thats what happened to my friend chris's 94 z28
00 ws6 vert a4 ( mods in garage ) 87 fullsize bronco ( 35 inch mud terrains ) 85 iroc ( lt1 and 6 speed ) honda 450r honda 400ex gf's
im not sure, but that could be from someone mixing tap or well water in the coolant system, instead of distilled or whatnot.
had an old chevy pickup 305 looked like that also.
so i was just outside getting ready to do a coolant flush, and this is what i saw when i took the radiator cap off....
wtf
That is what happens when you use Dex-Cool (Red) Coolant. It is crap in our engine, causing havoc with our coolant system. (Including heater core failure) The thing that sucks is that GM knows about this and does nothing.
Flush it out really well several times using concentrated coolant system cleaner, then use the Yellow/Green Coolant (Not The Red).
There are many documented cases of Dex-Cool causing major problems including damage to head and intake gaskets.
the green stuff is the only coolant i will use
10/9/1987-6/30/2007
None
