My Trans Am's gear ratio is insane
    Quit being lazy. Climb under and pull the cover and find out.
      bet it had gears installed and they didn't replace the speedo gear.
      5th in a t5 is .63 I think
      http://www.f-body.org/gears/
        If I get a chance while at school tomorrow I'll throw it on a lift and pull the cover. I hate not knowing.
          jack up the rear and spin the rear tires. count tire revolutions vs. drive shaft revolutions
            It would be good to find out. That will effect your gas mileage big time.
              whats really stupid is that even with this insane gear ratio, the diff is open. Not even posi.
              I have a posi diff in the shed; I need to rebuild it with some 3.73's and throw it in.
                Now I know
                Well I finally got the car up on a lift and pulled the cover.
                The lube was not in very good condition. Looked like it had NEVER been changed. Surprisingly there was basically no metal in the fluid that I could feel so not much wear. I marked the gears with paint and counted teeth, but then felt stupid cause I noticed the ring gear had the factory stamping on it. Its a GM 3.73 41/11 gearset, and non-posi.
                I was kinda thinkin it would be cool to have 4.11's but honestly I think I will be happier with these 3.73 gears. 4.11's are pretty steep for a 3rd gen thats not built up.
                Now that I know the gears are 3.73's I can start pulling my other differential apart thats posi and get it ready to swap the 3.73's into it.
                  sounds awsome!! Yeah I like my 3.73.
                    With all the expressway driving I do, I am really glad I don't have 3.73 in my daily Bird.
                    Currently Owned F-Bodies
                    1994 Firebird 3.4L V6 SPI, T5, Black with T-Tops and Leather Interior (Daily Driver)
                    1985 Trans-Am 383 Stroker Carb., Black with T-Tops (Hobby Car)
                    1986 Trans-Am 5.0L TPI, Blue with T-Tops. (Project Car)
