ok so i bought a centerforce clutch for my camaro and i was looking at the clutch and i seen the current location of the dowel pins is not in the same spot as the new pressure plate do i have to move the dowel pins on the flywheel or is it even possible to move them on the stock flywheel or did i just order the wrong clutch?
were i marked is where they currently sit but in the new pp there is no hole in any spot for them other than down further which would require them to be moved
