I know its possible really, but how tough a job is it? Anybody do it before? How bad a job is it?
If you have done it would you do it again? I had a dream last night that I just cant shake, bet you can guess what it was!
So, trans and cross member. Flywheel, clutch, clutch pedal and bracket, different brake pedal. Is the clutch hydraulic or mechanical? Is the drive shaft the same as the automatic?
What about the trans tunnel and related holes are they different from auto to manual? console is different to Im sure
