Has anyone installed the 25% underdrive pulley ? What brand ? did you notice any increase in power ? Is it true the engine revs quicker ? I just wanna know if its worth the investment ?
Underdrive pulley
I had a 2 piece march under drive kit on my old 4th gen. Had the smaller alt pulley and the crank.
Arguably one of the better mods that I did to the car. No real issues aside from the Voltage. Pulled a lot harder. At idle with the a/c on, headlights, fans, the voltage would hit the 12s. Had to tune the idle up to 1,000 and that resolved the issues. Don't plan on running any major electronics after the swap.
Also, I highly recommend upgrading the vehicle's ground points with some 4 gauge wires or larger. I picked up another volt just from that alone.
InActive Member- May 31st, 2013
- 243
- James M.
- 1997 Chevrotlet Camaro Base Model V6 M5
- Commerce Twp, MI
- Senior Engineer - Vehicle Calibration
Thanks for the follow up comment on 4 gauge ground wires. I was wondering if there was an issues as see my volts drop of significantly at idle on stock pulleys with no electronics going.Originally posted by ruckusz28 View PostI had a 2 piece march under drive kit on my old 4th gen. Had the smaller alt pulley and the crank.
I don't have any extra electronics aside from some gauges so I didn't have any voltage issues but I added a larger Lid/MAF setup and an ASP underdrive pulley and netted a 20rwhp gain, not sure which had more effect but I was happy with the results.Doing less with more
- Lowell, MI
- Meat Processor
This makes me think....did my BBK setup come with a larger alternator pulley?Originally posted by SOPES View PostI think Im gonna do just the crank pulley, I plan on putting a bass tube in eventually
