TRANSMISSION
  • TRANSMISSION
    sad to say i think my transmission is blown... i have a 94 25th anniversary automatic. anyone have any idea of how much this will cost me if this is the case? or can i get a used one ect... pretty bummed out
    GO BLUE
    To have the shop do all the work, it can run as high as $1800 (or more with options)
    $300 should get you a nice used one but you'll have quite a bit of time invested in swapping them. You'll need a 4L60e from a 94-97 f-body (or 92-95 corvette, 93-96 Impala/Caprice if you swap tail housings) not a regular 4L60/700r4
      Cost me $3000 to have a shop do my T56...Stupid!! Make sure you pull that thing out yourself if you plan on taking it somewhere.
      98 Trans Am WS.6
      Cam
      Heads
      Intake
      Full exhaust
      More mods to come
        That's entirely too much money for a rebuild....you can find brand new OEM t56's for that price. If you went with all the bells and whistle then it's a different story
          Yeah I came to find this out later...that doesn't even include the money for the new clutch or the money I spent on a rental car for a two weeks. It pretty much was new once they were done with it, but I will never go back to West Michigan Transmission again! The worse part about it is I was recommended to that place by a mifbody member.
          98 Trans Am WS.6
          Cam
          Heads
          Intake
          Full exhaust
          More mods to come
            Sorry Mike for messing up the thread, but I like talking transmissions
            Anthony, do you remember what they did? If all the gears are good (no worn dogs, no pitted gears) I can do a master rebuild for under $700, a basic syncro rebuild for less than $350. That's including my time.
              ill be selling my 4l60e eventually, no problems as far as im aware of.
              1997 Trans Am
              T56 swap. LS1 Cosmetics
                If your dropping the car off somewhere, I would say expect a MINIMUM of $1300-1500. If you need anything more than a stock rebuild expect more.
                  Yup, I'd say 1300-1800 for parts and labor is about standard for any common US passenger car/light duty pickup automatic transmission rebuild.
                    i just re-built my tranny, same trans for about 285-300$ for all the internals, and fluid, filter and gaskets.
                      They replaced 4 of the gears and the main shaft, can't remember exactly what...but I have a box of parts that they replaced.
                      98 Trans Am WS.6
                      Cam
                      Heads
                      Intake
                      Full exhaust
                      More mods to come
                        Ouch, so it was rode hard and put away wet
                          Pm sent to OP
                            Hey mike I responded to your PM.. Thanks for the info guys!
                            GO BLUE
                              ***UPDATE***
                              it was the transmission mount.. It was cracked only $123 to fix back on the road!
                              GO BLUE
