Operation 9"
Obsessed
- December 28th, 2005
- 931
- Friends call me Cat.
- '87 305 IROC Z Bride nick named my ride as "The Ole Whore". IDK, jealous maybe?
- Jackson
- Civil Servant
Well, I am no suspension guru by any means.. Need some input.. Judging by what I see and what you see in the pics below I am guessing the pig needs to rotate forward for the springs to sit right. I am,also, guessing I will need to adjust my LCA's to allow this to happen? I measured center of axle on both sides 15 7/8". Looks like it needs to rotate a good amount and without extending the LCA's, I am not sure how else to do it.. Let's hear your thoughts..
IMAG0136.jpgIMAG0137.jpgsigpic
This I know. Had the 10 bolt set at -2.Originally posted by c0ncEpT View PostPinion angle is usually set between -1 and -2 and ride height.
I understand how to set pinion and that is it on a jack.. Is it normal to be that far off? There is no way I can put my torque arm on right now without getting the pig to rotate down.Originally posted by 1BADAIR View Post1. its hanging. check at curb height
2. pinion angle will need adjusta-curb heightsigpic
Yep, that was my next move. I put the jack under the panahard bar mount and lifted there. that rotated the pig downward.. Does anyone have a pic of how the springs should look when correct? Mine are flush on the front side and gapped on the back(I know they are coils and there will be a gap). Just wondered if it makes a difference where that gap is..Originally posted by 1BADAIR View Postso , the TA isnt in? my springs always look like that while in the air. to get the TA i put the jack under the axle PHB mount to rotate it downsigpic
Don't worry about the springsOriginally posted by OIF1VET View PostYep, that was my next move. I put the jack under the panahard bar mount and lifted there. that rotated the pig downward.. Does anyone have a pic of how the springs should look when correct? Mine are flush on the front side and gapped on the back(I know they are coils and there will be a gap). Just wondered if it makes a difference where that gap is..
They'll center themselves.
Everything will look better once the torque arm is in place.
Make sure the rear is centered and square and you'll be good!2000 Formula
fixed slow junk
I have the TA in, but not completely mounted.. I did rotate the pig down by jacking where the panhard bar locates. I then put a jack on the opposite side to hold it in place. I had the TA completely mounted, then realized one of the TA bracket mount bolts was out(I had to take it out to file down a spot so the TA would slide all the way back on mount). Of course that bolt won't go in with the TA in place, so out came the bolts again. Re-installed TA bracket mount bolt and of course I can't get both mount bolts in. Got one, finally said **** it on the other.. I need to find a better prybar to persuade the bolt to go in..sigpic
Yes, 2 sets of holes. So you're saying I should be using the other set of holes in pic?Originally posted by 1BADAIR View Posttwo sets of holes on your TA? for awhile , you have to cut the outer set off when using a 9 inch so you could use the inners and get the TA straight
IMAG0140.jpgsigpic
It looks straight.Originally posted by 1BADAIR View Postmmm, probably. does the TA look straight back from the front to the axle. you usually also have to have it in the inner to help some with the TA to floor issue at the top left corner of the axle mount in your picLast edited by OIF1VET; March 18th, 2012, 05:20 PM.sigpic
As usual, I believe you are correct Larry. I moved it over 1 set of holes, I do have clearance for the DS without cutting anything.. Here's a pic, this looks pretty straight to me..
IMAG0141.jpgsigpic
Looked on spohns site. Just a FYI for the next guy. Thanks L3 for the heads up.
- Ford 9” Rears: You will notice that the rear mounting bracket of the torquearm has two sets of mounting holes. On the 9” rear you want to use the setof mounting holes that are towards the driver’s side of the car. On a stockrear or 12 bolt rear, you would use the set of mounting holes towards thepassenger’s side of the car. The reason for this is that on a 9” rear, due to thelarger center section, the torque arm mount on the rear is actually 1” furtherto the driver’s side of the car compared to the OEM rear. Using the set ofholes towards the driver’s side of the car in our rear mounting bracket willmove the torque arm back to the OEM location and line it straight up with thefront mount. If your 9” rear is equipped with a nodular (large ribbed) centersection, it may be necessary to grind away part of the rib so it does notinterfere with the torque arm’s rear mounting bracket.
