Operation 9"
Geez Larry, do you need me to come clean up the underside of your car? Looks filthy... I expect better
Alright, a few updates.. I did the heater hose mod this morning. No idea on drop cause car is in the air.. But with the rear sitting on jackstands center of axle to bottom of wheelwell is 15 3/4", measured almost 17" when I checked it the same way last weekend.. Transverse shock mounts and shock bearings in. Everything is hooked up and in it's proper place. I have not tightened anything yet though. Still need to bleed the brakes also..
Shocks as mounted on 10 bolt and crappy old bushings(how I never saw this I have no idea). and pic of new bearings and mount..
Leave a comment:
Whatever helps you sleep at night.Originally posted by OVRKILL View PostOr cheap ass red-neck vs engineered solution.....
Leave a comment:
Originally posted by OVRKILL View PostWord....
Have the fix for that
Those come from the guy on ls1tech? Going to be installing a set of those this weekend.
Leave a comment:
Good! Yeah wanted to make sure you were taking all your measurements with the suspension loaded.
Leave a comment:
Well at least I know it is sitting right now.. Now just wait on those brackets, bearing kit, and TA mount bolts. Measure for DS, bleed brakes.. Thanks for all the input everyone..Originally posted by Nocooler View PostYup the 9" raises the rear of the car about an inch.
Leave a comment:
Alright hooked up ARB, centered it on axle and tightened U bolts.. Left adj rods loose but attached. Sat car back down, I was with in 1/2" now. IIRC I was 28 Pass, 28.5 driver side. Axle is also centered now.. I measured each Adj rod length center of bolt to center, drivers side was 7" long, Pass side 8".. Done for the day, need a little down time before work..
Edit: After talking to Sean I am going to do the heater hose mod to drop it that 1/2 to 3/4" I need to come down. I had no idea a 9" would raise my car that much..Last edited by OIF1VET; March 21st, 2012, 01:19 PM.
Leave a comment:
Leave a comment:
