Operation 9"
  • Originally posted by Nocooler View Post
    Yup the 9" raises the rear of the car about an inch.
    Well at least I know it is sitting right now.. Now just wait on those brackets, bearing kit, and TA mount bolts. Measure for DS, bleed brakes.. Thanks for all the input everyone..
      Word....
      Have the fix for that
      • Originally posted by OVRKILL View Post
        Word....
        yeah its called the heater hose mod.. super easy and cheap
          Word....
          • Good! Yeah wanted to make sure you were taking all your measurements with the suspension loaded.
              If I never have to do another rear, it will be to soon...
                Or cheap ass red-neck vs engineered solution.....
                  Word....
                  Those come from the guy on ls1tech? Going to be installing a set of those this weekend.
                    Whatever helps you sleep at night.
                      exactly...
                        Yep....
                        ....like a baby.
                        • Alright, a few updates.. I did the heater hose mod this morning. No idea on drop cause car is in the air.. But with the rear sitting on jackstands center of axle to bottom of wheelwell is 15 3/4", measured almost 17" when I checked it the same way last weekend.. Transverse shock mounts and shock bearings in. Everything is hooked up and in it's proper place. I have not tightened anything yet though. Still need to bleed the brakes also..
                          Shocks as mounted on 10 bolt and crappy old bushings(how I never saw this I have no idea). and pic of new bearings and mount..
                          • Geez Larry, do you need me to come clean up the underside of your car? Looks filthy... I expect better
                              come on over..
                              • Originally posted by OIF1VET View Post
                                come on over..
                                He won't even come to my house for garage ***** duty.....sure as hell won't be headed to Skegon
