Hey guys Im trying to get the camaro back together in time for the harper cruise. Im putting the rear brakes back together with new parts. and I noticed the pads have these little tabs of them that seem to stop the pad from resting against the front of the caliper. Now that I have it together the one side i have done seems a bit tight. I can still spin it by hand but slowly since Im turning the whole rear end. Im thinking if I just put it in drive and let it wear a little space for it self it should be fine. what do you think? I guess I could pull it apart and wear down those tabs instead, but I don't know why they are there.
Rear brakes tight
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
- Electro-Mechanical Engineer
Rear brakes tight
pics? I think I have the same problem with my LS rear brakes, looks like the caliper bracket is going to rub the rotor'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
No, no pics yet sorry. However after taking a second glance at it, it looks like it will be fine. Now I just gotta figure out what they call that mounting bar that the slides ride in, had a slide bust off in the piece, I cant get it out and if its cheap enough I'll just get a new oneThe Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
Lt1The Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
